* bspgetworkarea.c: Fix typo. Add debug printk statements.
* bspgetworkarea.c: Augment to optionally know U-Boot.
* bootcard.c: Perform bsp_start() before bsp_get_work_area().
* bootcard.c: Add support for optionally having a unified work area. In
other words, the RTEMS Workspace and C Program Heap are the same pool
of memory.
* bsplibc.c, bsppost.c: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* bspgetworkarea.c: New file. This implementation should be useable
by most BSPs if they provide the proper support in their linker script.
* clockdrv_shell.c: Remove unnecessary includes of rtems/libcsupport.h
and rtems/libio.h.
* bspstart.c: New file.
* clockdrv_shell.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* timerstub.c, tod.c: Convert to "bool".
* tod.c: Remove extern. RTC_Present is not defined anywhere.
PR 1302/bsps
* vmeUniverse/vmeUniverse.h: Remove
_VME_UNIVERSE_DECLARE_SHOW_ROUTINES.
Remove _VME_UNIVERSE_DECLARE_SHOW_ROUTINES.
* timerstub.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* bootcard.c: Fix formatting.
* console-polled.c: Error if minor < 2 not just <= 2.
* vmeUniverse/vmeTsi148.h, vmeUniverse/vmeTsi148.c:
added vmeTsi148ResetBusXX(), vmeTsi148ResetBus().
* src/irq-generic.c: Fixed integer conversion warnings.
* timerstub.c: Add missing prototypes.
* include/bootcard.h, bootcard.c, bsplibc.c: Changed parameter types of
bsp_libc_init() to match RTEMS_Malloc_Initialize().
* bsppost.c, bsppredriverhook.c: Include bootcard.h.
* src/irq-generic.c: Fixed warnings.
* bsppost.c: Fix warning by moving prototype to libcsupport.h.
* tod.c: Add missing prototypes.
PR 537/bsps
* bsplibc.c: Eliminate vestiges of ticks_per_timeslice controlling
newlib reentrancy. The parameter was ignored in libc_init().
bootcard.c: Check if the heap fits into the work area
added support for an optional separate heap area.
* bootcard.c: Must include bsp.h or bspopts.h or we cannot know if
boot_card() handles RAM allocation.
updated haleakala BSP
added MPC55xx BSP
(shared handler and handler with a handle).
* include/tm27.h: New file. Stub version of tm27 support.
* vmeUniverse/VME.h: removed 'weak' attribute from
declaration of BSP_vme_config().
* vmeUniverse/vmeUniverse.c: fixed compiler warning;
moved struct attributes as directed by gcc warning.
* bootcard.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* bsppretaskinghook.c: New file.
* bootcard.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* bootcard.c: Improve formatting and comments.
* vmeUniverse/vmeTsi148.c: type of 5th argument
to pci_read_config_dword() is now uint32_t*.
* vmeUniverse/vmeTsi148.c: Initialize VME Master
'VTON' timer and bus-release policy to less aggressive
values than the chip's defaults. The default VTON easily
overrides any settings used by the DMA engine.
* gdbstub/rtems-stub-glue.c: Update to use the new
rtems_object_get_name() service. This simplified the code a bit.
* bootcard.c: Improve comments and clean up argc/argv order.
* bootcard.c, bsplibc.c: Eliminate copies of the Configuration Table.
Use the RTEMS provided accessor macros to obtain configuration
fields.
* bootcard.c: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* bsppredriverhook.c: New file.
* bootcard.c: Moved most of the remaining CPU Table fields to the
Configuration Table. This included pretasking_hook, predriver_hook,
postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeTsi148.c:
silenced compiler warnings caused by type changes
in byteorder.h (volatile unsigned * -> volatile uint32_t *)
* bootcard.c: Add comment.
