Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
Update #2271.
This patch adds support for the following devices to the LPC176x BSP:
* CAN
* PWM
* ADC
It also adds the probe routines for UART1/2/3 to the console_device_table in console-config.c, and enables UART1 in configure.ac.
Only a few BSPs use this and it should not have been in libcsupport.
Update #2268.
Use the fstat handler instead.
This allows the BSP to define an optional spin delay which is
useful for making time appear to pass at a rate closer to
wall time. On the Edison, this was used with a polled console
driver to slow polling to a reasonable rate and make time
pass reasonably close to correctly even with no clock tick
support.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
The extra includes in console_*.c are to solve a 'no previous prototype'
warning.
Solves #2212 in trac.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
Simplify initialization. Replace some assert() with fatal errors.
Check that data cache snooping exists and is enabled on all cores.
methods in file
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
Manupilating the interrupt control registers directly instead
of going through the interrupt layer can be deceiving.
Add a simple Termios console driver using a table for statically
registered devices used in console_initialize() and dynamic installation
via console_device_install().
This rippled into the handful of files that should have been using
<rtems/tod.h>.
output.
All,
This patch is submitted as its values are used in my to-be-submitted
beagle bsp.
Add and use _CPU_SMP_Start_processor(). Add and use
_CPU_SMP_Finalize_initialization(). This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
A new option RTEMS_INTERRUPT_REPLACE is introduced that permits updating
the first interrupt handler for the registered interrupt vector and
matching argument. If no match is found, the install function fails
with RTEMS_UNSATISFIED.
The Interrupt Manager Extension offers interrupt handlers with an
argument pointer. It is impossible to update two words (handler and
argument) atomically on most architectures. In order to avoid an SMP
lock in bsp_interrupt_handler_dispatch() which would degrade the
interrupt response time an alternative must be provided that makes it
possible to tear-down interrupt sources without an SMP lock.
Add RTEMS_INTERRUPT_REPLACE option to Interrupt Manager Extension. This
enables a clean tear-down of interrupt sources on SMP configurations.
Instead of an interrupt handler removal a replacement handler can be
installed to silence an interrupt source. This can be used in contexts
that allow no sophisticated synchronization (e.g. in atexit() or fatal
handlers).
The vector number of spurious interrupts was wrong after the interrupt
handler removal on SMP configurations.
