* | shared vmeUniverse: Improve Doxygen | Szkocsovszki Zsolt | 2014-01-08 | 1 | -3/+14 |
* | 2009-05-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-05-27 | 1 | -4/+4 |
| | | | | * tod.h, tod.c: Update for new RTC driver interface. | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 1 | -1/+0 |
| | | | | | | * bootcard.c, bspclean.c, clockdrv_shell.c, console-polled.c, console.c, ide_ctrl.c, main.c, sbrk.c, setvec.c, tod.c, tod.h, include/coverhd.h: URL for license changed. | ||||
* | Added getRealTime() and setRealTime(). | Joel Sherrill | 1998-07-30 | 1 | -7/+32 |
| | | | | Reimplemented checkRealTime() to use RTEMS internal routine. | ||||
* | Made tod.h shared | Joel Sherrill | 1998-07-30 | 1 | -0/+38 |
