Update #3285.
The RTEMS print user need to know nothing about a particular printer
implementation. In particular get rid of the <stdio.h> include which
would be visible via <rtems.h>.
of this patch set.
* include/irq-config.h: Removed file.
* include/irq.h: New file (renamed from 'include/irq-config.h').
* include/irq-generic.h, src/irq-info.c: Include <bsp/irq.h> instead
of <bsp/irq-config.h>.
* src/irq-server.c: Use events instead of semaphore. Added error
counter for multiple chain appends. Added error counter to detect
erroneous interrupt events.
* include/irq-config.h, include/irq-generic.h, include/irq-info.h,
src/irq-generic.c, src/irq-info.c, src/irq-legacy.c, src/irq-shell.c:
Format, cleanup and documentation.
* src/irq-server.c: New file.
* include/bootcard.h, include/stackalloc.h, src/stackalloc.c,
bsplibc.c: Update for heap API changes. Documentation.
* include/irq-info.h, src/irq-info.c, src/irq-shell.c: New files.
* include/irq-generic.h, src/irq-generic.c: Improved interrupt handler
dispatch function.
