* bootcard.c, bspclean.c, clockdrv_shell.c, console-polled.c,
console.c, ide_ctrl.c, main.c, sbrk.c, setvec.c, tod.c, tod.h,
include/coverhd.h: URL for license changed.
effects in RTEMS source code.
* sbrk.c: Corrected prototype to match newlib.
returned an error to using a single shared copy of this file.
