Make rtems_initialize_data_structures(),
rtems_initialize_before_drivers() and rtems_initialize_device_drivers()
static. Rename rtems_initialize_start_multitasking() to
rtems_initialize_executive() and call the registered system
initialization handlers in this function. Add system initialization API
available via #include <rtems/sysinit.h>. Update the documentation
accordingly.
This is no functional change, only the method to call the existing
initialization routines changes. Instead of direct function calls a
table of function pointers contained in the new RTEMS system
initialization linker set is used. This table looks like this (the
actual addresses depend on the target).
nm *.exe | grep _Linker | sort
0201a2d0 D _Linker_set__Sysinit_begin
0201a2d0 D _Linker_set__Sysinit_bsp_work_area_initialize
0201a2d4 D _Linker_set__Sysinit_bsp_start
0201a2d8 D _Linker_set__Sysinit_rtems_initialize_data_structures
0201a2dc D _Linker_set__Sysinit_bsp_libc_init
0201a2e0 D _Linker_set__Sysinit_rtems_initialize_before_drivers
0201a2e4 D _Linker_set__Sysinit_bsp_predriver_hook
0201a2e8 D _Linker_set__Sysinit_rtems_initialize_device_drivers
0201a2ec D _Linker_set__Sysinit_bsp_postdriver_hook
0201a2f0 D _Linker_set__Sysinit_end
Add test sptests/spsysinit01.
Update #2408.
Update #2408.
Call bsp_work_area_initialize() before bsp_start(). This allows
bsp_start() to use malloc() etc. which is beneficial for systems with a
plug-and-play hardware enumeration.
Update #2408.
Close #2477.
Closes #2435.
makes rtems_gpio_bsp_get_value return uint32_t. Motivation: simplify
beagle gpio implementation for common gpio apio.
Changes relative to the previous patch set:
- Moved GPIO pin interrupts to rtems chains, instead of a local linked list;
- Restructured the pin tracking structure, separating the interrupt information for each pin meaning that a pin without any interrupt enabled only requires 8 bytes, while keeping interrupt information (handling information, handler chain control, ...) requires 24 additional bytes (total of 32 bytes per pin with interrupts enabled);
- Added support for 'parallel' pin function assignment, allowing the function assignment to be set for multiple pins in a single GPIO hardware call. If a BSP does not support this feature it becomes a sequence of individual calls per pin. Also added support for GPIO pin groupings, allowing to write and read byte data to a series of pins which behave as a single entity;
- Added bank tracking structure to maintain the bank lock and bank level interrupt information (threaded/normal handling, interrupt counter);
- Changed GPIO settings to BSP defined constants, reducing dynamic memory allocation;
- Switched interrupt tasks for a rtems interrupt server, with the possibility of using normal interrupts (user handlers being called within ISR context).
This patch adds support for the following devices to the LPC176x BSP:
* CAN
* PWM
* ADC
It also adds the probe routines for UART1/2/3 to the console_device_table in console-config.c, and enables UART1 in configure.ac.
Only a few BSPs use this and it should not have been in libcsupport.
Simplify initialization. Replace some assert() with fatal errors.
Check that data cache snooping exists and is enabled on all cores.
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
Manupilating the interrupt control registers directly instead
of going through the interrupt layer can be deceiving.
Add a simple Termios console driver using a table for statically
registered devices used in console_initialize() and dynamic installation
via console_device_install().
All,
This patch is submitted as its values are used in my to-be-submitted
beagle bsp.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
This patch refactors a lot of the existing doxygen within libbsp/arm/lpc32xx.
Much of this refactoring was just renaming of existing groups to conform to a
more consistent naming structure. With the addition of a doxygen header for
tm27.h, all files within lpc32xx belong to doxygen group now. lpc32xx should
be used a reference for adding doxygen to other bsps.
Add support for MMU initialization for RaspberryPi. Introduce new shared
MMU configuration table that can be used by other BSPs that call the
arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function.
Demonstrate the use of the generic table with RaspberryPi.
Add bsp_generic_fatal().
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use rtems_fatal() instead of bsp_cleanup().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
