* | shared vmeUniverse: Improve Doxygen | Szkocsovszki Zsolt | 2014-01-08 | 1 | -0/+16 |
* | Shared MMU initialization for ARM BSPs and RaspberryPi MMU support | Hesham AL-Matary | 2013-10-03 | 1 | -0/+25 |
Add support for MMU initialization for RaspberryPi. Introduce new shared MMU configuration table that can be used by other BSPs that call the arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function. Demonstrate the use of the generic table with RaspberryPi. |
