Fatal errors must uniquely identify the source location.
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
* shared/console-polled.c:
Reflect changes to rtems_termios_callbacks->write.
* bootcard.c, bsplibc.c, clockdrv_shell.h, console-polled.c: Fix
formatting.
* bootcard.c: Fix formatting.
* console-polled.c: Error if minor < 2 not just <= 2.
* bootcard.c, bspclean.c, clockdrv_shell.c, console-polled.c,
console.c, ide_ctrl.c, main.c, sbrk.c, setvec.c, tod.c, tod.h,
include/coverhd.h: URL for license changed.
* console-polled.c: Corrected comments in header.
* console-polled.c, console.c: Fixed typo.
* clockdrv_shell.c: Added fast idle mode which is enabled by defining
CLOCK_DRIVER_USE_FAST_IDLE.
* console-polled.c: Added console_initialize_hardware() hook.
* console-polled.c: Remove warnings.
to do polled IO on a single port with VERY little support code.
