* | 2009-12-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-10 | 1 | -2/+2 |
| | | | | | * shared/console-polled.c: Reflect changes to rtems_termios_callbacks->write. | ||||
* | 2009-08-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-28 | 1 | -10/+10 |
| | | | | | * bootcard.c, bsplibc.c, clockdrv_shell.h, console-polled.c: Fix formatting. | ||||
* | 2008-08-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-08-30 | 1 | -1/+1 |
| | | | | | * bootcard.c: Fix formatting. * console-polled.c: Error if minor < 2 not just <= 2. | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 1 | -1/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -7/+7 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
| | | | | | | * bootcard.c, bspclean.c, clockdrv_shell.c, console-polled.c, console.c, ide_ctrl.c, main.c, sbrk.c, setvec.c, tod.c, tod.h, include/coverhd.h: URL for license changed. | ||||
* | 2003-06-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-06-30 | 1 | -2/+3 |
| | | | | * console-polled.c: Corrected comments in header. | ||||
* | 2001-10-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-10-12 | 1 | -1/+0 |
| | | | | * console-polled.c, console.c: Fixed typo. | ||||
* | 2001-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-01-03 | 1 | -0/+8 |
| | | | | | | * clockdrv_shell.c: Added fast idle mode which is enabled by defining CLOCK_DRIVER_USE_FAST_IDLE. * console-polled.c: Added console_initialize_hardware() hook. | ||||
* | 2000-12-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-05 | 1 | -6/+0 |
| | | | | * console-polled.c: Remove warnings. | ||||
* | New file. This is a simple termios console driver which is sufficient | Joel Sherrill | 2000-06-12 | 1 | -0/+148 |
to do polled IO on a single port with VERY little support code. |
