path: root/c/src/lib/libbsp/shared/bspreset_fatal.c (unfollow)
2013-06-24bsps: Delete bspreset_fatal.cSebastian Huber1-15/+0
Use bspreset_loop.c instead. This avoids infinite recursion.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2008-09-222008-09-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+4
* bspclean.c, include/bootcard.h: Use standardized bsp_cleanup() which can optionally print a message, poll for user to press key, and call bsp_reset(). Using this eliminates the various bsp_cleanup() implementations which had their own implementation and variety of string constants. * bspreset.c, bspreset_fatal.c, bspreset_loop.c: New files.
2008-09-152008-09-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-4/+5
* shared/bspgetworkarea.c, shared/bsphwinit.c, shared/bspstart.c: New files.
2008-09-052008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-4/+3
* Makefile.am, preinstall.am, shmsupp/getcfg.c, shmsupp/lock.c, startup/linkcmds: Now running mptests using new memory layout with updates patches against gdb 6.8. * include/psim.h, startup/psim_registers.c: New files.
2008-04-182008-04-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+2
* rtems/mainpage.h: New file.
2007-12-172007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-0/+11
* score/mainpage.h: Sweep to make sure grep for COPYRIGHT passes.
2004-11-012004-11-01 Joel Sherrill <joel@oarcorp.com>Joel Sherrill1-0/+5
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/copyrt.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/mppkt.inl, score/inline/rtems/score/objectmp.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/states.inl, score/inline/rtems/score/sysstate.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/threadmp.inl, score/inline/rtems/score/tod.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/watchdog.inl, score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working modifications which are not complete and may have broken code. Committing so work and testing can proceed. * score/Doxyfile, score/mainpage.h: New files.
