* | 2008-09-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-22 | 1 | -0/+17 |
* bspclean.c, include/bootcard.h: Use standardized bsp_cleanup() which can optionally print a message, poll for user to press key, and call bsp_reset(). Using this eliminates the various bsp_cleanup() implementations which had their own implementation and variety of string constants. * bspreset.c, bspreset_fatal.c, bspreset_loop.c: New files. |
