Update #2408.
Rename open_dev_console() to rtems_libio_post_driver(). Rename
rtems_libio_supp_helper to rtems_libio_post_driver_helper.
Add and use rtems_libio_helper function type. Add and use
rtems_libio_helper_null() instead of NULL pointer.
* bsppost.c: Fix typo.
* bsplibc.c, bsppost.c: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* include/bootcard.h, bootcard.c, bsplibc.c: Changed parameter types of
bsp_libc_init() to match RTEMS_Malloc_Initialize().
* bsppost.c, bsppredriverhook.c: Include bootcard.h.
* src/irq-generic.c: Fixed warnings.
* bsppost.c: Fix warning by moving prototype to libcsupport.h.
* bsppost.c: Split open of the console from the standard BSP code so it
is easier to stub out.
PR 1232/bsps
* bsppost.c: It should not be a fatal error to not have a console.
PROBLEMS
can/will be fixed.
component.
