* include/irq-config.h, include/irq-generic.h, include/irq-info.h,
src/irq-generic.c, src/irq-info.c, src/irq-legacy.c, src/irq-shell.c:
Format, cleanup and documentation.
* src/irq-server.c: New file.
* include/bootcard.h, include/stackalloc.h, src/stackalloc.c,
bsplibc.c: Update for heap API changes. Documentation.
* bootcard.c, bsplibc.c, clockdrv_shell.h, console-polled.c: Fix
formatting.
* bsplibc.c, bsppost.c: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* include/bootcard.h, bootcard.c, bsplibc.c: Changed parameter types of
bsp_libc_init() to match RTEMS_Malloc_Initialize().
* bsppost.c, bsppredriverhook.c: Include bootcard.h.
* src/irq-generic.c: Fixed warnings.
PR 537/bsps
* bsplibc.c: Eliminate vestiges of ticks_per_timeslice controlling
newlib reentrancy. The parameter was ignored in libc_init().
* bootcard.c, bsplibc.c: Eliminate copies of the Configuration Table.
Use the RTEMS provided accessor macros to obtain configuration
fields.
PR 1237/rtems
* src/lib/libbsp/shared/bsplibc.c: Add logic to prevent stack creep
when interrupts occur at a sufficient rate that the interrupted
thread never gets to clean its stack. This patch ensures that an
interrupted thread will not nest ISR dispatches on its stack.
* bsplibc.c, clockdrv_shell.c, ide_ctrl.c, tod.c,
gdbstub/rtems-stub-glue.c: Convert to using c99 fixed size types.
* bsplibc.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
PROBLEMS
can/will be fixed.
+ adding #include <rtems/libio.h> to fix implicit declaration warning
bspstart.c file.
