The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
* shared/bspgetworkarea.c: Use BSP_DISABLE_UBOOT_WORK_AREA_CONFIG and
BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN options.
* shared/bspgetworkarea.c: Include <bsp/u-boot.h> if necessary.
* shared/include/u-boot.h, shared/src/bsp-uboot-board-info.c: New
files.
* bootcard.c, bspgetworkarea.c, include/bootcard.h: Switch from ssize_t
to uintptr_t for bsp_get_work_area() since the work area is larger
than a single allocatable object.
* bspgetworkarea.c: Add check to determine if current stack pointer is
in work area.
* bootcard.c, bspgetworkarea.c, bsppretaskinghook.c,
include/bootcard.h: Change size_t to ssize_t on bsp_get_work_area().
On 16-bit architectures, size_t can be 16-bits which would limit the
work area to 64K.
* bspgetworkarea.c: Fix typo. Add debug printk statements.
* bspgetworkarea.c: Augment to optionally know U-Boot.
* bspgetworkarea.c: New file. This implementation should be useable
by most BSPs if they provide the proper support in their linker script.
