path: root/c/src/lib/libbsp/shared/bspclean.c (follow)
* Switch to using a shared main() for all of the embedded BSPsJoel Sherrill1998-03-211-0/+17
based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path.
