* ide_ctrl.c: Include <rtems/chain.h> instead of <chain.h>.
* bsplibc.c, clockdrv_shell.c, ide_ctrl.c, tod.c,
gdbstub/rtems-stub-glue.c: Convert to using c99 fixed size types.
* ChangeLog: Merge-in gdbstub/ChangeLog.
* gdbstub/ChangeLog: Remove.
PR 501/rtems_misc
* console.c: console_open disables ICANON on non-console port, which
should be ok for the first open but not for subsequent ones. If you
open one serial port, you will configure it, when you reopen it you
will lost the ICANON parameters if you had put it. Should be done by
console only at first open.
* bootcard.c, bspclean.c, clockdrv_shell.c, console-polled.c,
console.c, ide_ctrl.c, main.c, sbrk.c, setvec.c, tod.c, tod.h,
include/coverhd.h: URL for license changed.
* include/Makefile.am: Remove (merged into Makefile.am).
* gdbstub/Makefile.am: Remove (merged into Makefile.am).
Reflect having merged ../configure.ac into ../../../configure.ac.
* console-polled.c: Corrected comments in header.
PR 380/bsps
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h:
make printk format strings compliant with libcpu/printk.
minor fixes and lazy init bugfix.
PR 349/bsps
* shared/README.universe, shared/vmeUniverse/README.porting
shared/vmeUniverse/README.universe, shared/vmeUniverse/vmeUniverse.c,
shared/vmeUniverse/vmeUniverse.h: Update of the VME universe driver.
* ide_ctrl.c: New file.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue necessitating a move up.
* Makefile.am: Reflect new gdbstub directory.
* vmeUniverse/README.universe, vmeUniverse/vmeUniverse.c,
vmeUniverse/vmeUniverse.h: New files.
* Makefile.am: Modified to reflect addition of files.
* Per PR214, contributes a driver for the TUNDRA UNIVERSE
VME-PCI bridge to libbsp/shared.
NOTE: This driver is maintained _outside_ RTEMS by Till. Please
forward future modifications to him.
* bootcard.c: Use __USE_INIT_FINI__ since USE_INIT_FINI
pollutes the application namespace.
* timerstub.c: New stub file for BSPs that don't have timer hardware.
* console-polled.c, console.c: Fixed typo.
* setvec.c: Removed unused variables.
* clockdrv_shell.c (CLOCK_DRIVER_ISRS_PER_TICK): Add support for
multiple ISRs per clock tick. Testing per hacking on mips/jmr3904
clock driver.
* clockdrv_shell.c: Fixed syntax error in fast idle support.
* clockdrv_shell.c: Added fast idle mode which is enabled by defining
CLOCK_DRIVER_USE_FAST_IDLE.
* console-polled.c: Added console_initialize_hardware() hook.
* console-polled.c: Remove warnings.
* clock_driver_stub.c: This is a stub of a clock driver that
is sufficient for linking the ticker application. Some
simulators do not have a soruce for a clock tick. Also
this can be used while constructing a BSP so everything links.
* bsplibc.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
effects in RTEMS source code.
* sbrk.c: Corrected prototype to match newlib.
