* bootcard.c: Use __USE_INIT_FINI__ since USE_INIT_FINI
pollutes the application namespace.
* timerstub.c: New stub file for BSPs that don't have timer hardware.
* console-polled.c, console.c: Fixed typo.
* setvec.c: Removed unused variables.
* clockdrv_shell.c (CLOCK_DRIVER_ISRS_PER_TICK): Add support for
multiple ISRs per clock tick. Testing per hacking on mips/jmr3904
clock driver.
* clockdrv_shell.c: Fixed syntax error in fast idle support.
* clockdrv_shell.c: Added fast idle mode which is enabled by defining
CLOCK_DRIVER_USE_FAST_IDLE.
* console-polled.c: Added console_initialize_hardware() hook.
* console-polled.c: Remove warnings.
* clock_driver_stub.c: This is a stub of a clock driver that
is sufficient for linking the ticker application. Some
simulators do not have a soruce for a clock tick. Also
this can be used while constructing a BSP so everything links.
* bsplibc.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
effects in RTEMS source code.
* sbrk.c: Corrected prototype to match newlib.
