* | Added scitab directory. | Joel Sherrill | 1998-07-17 | 2 | -1/+2 |
* | Patch fromalf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1998-07-17 | 1 | -0/+61 |
| | | | | | * c/src/lib/libbsp/sh/gensh1/scitab - NEW DIRECTORY Location for building the table generated by shgen | ||||
* | Removed extra (bad) CVS Id string. | Joel Sherrill | 1998-04-27 | 1 | -2/+0 |
* | Fixed CVS Id string and removed bogus comment. | Joel Sherrill | 1998-04-27 | 1 | -4/+1 |
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 2 | -31/+1 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 1998-04-15 | 2 | -46/+12 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -13/+0 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 1 | -8/+0 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 1 | -22/+0 |
| | | | | by newlib. | ||||
* | Moved bsp_postdriver_hook() to a shared file and made it a common | Joel Sherrill | 1998-03-30 | 2 | -28/+4 |
| | | | | component. | ||||
* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 3 | -22/+2 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | New port from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-03-20 | 2 | -0/+114 |
* | SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1998-03-20 | 13 | -0/+1248 |
