PR 1917/bsps
* console/config.c: Modifications to add dynamic tables for libchip
serial drivers.
* hw_init/hw_init.c:
* Makefile.am, preinstall.am, trap34/console-io.c: Install syscall.h as
bsp/syscall.h to avoid confusing autoconf.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* start/start.S: Verify boot_card is invoked properly with argc, argv.
* console/console.c: Reflect termios-API having changed.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/simsh1.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh2.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh2e.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh4.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gensh4.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gensh2.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gensh1.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh1.cfg: New (relocated from /make/custom).
* make/custom/simsh2.cfg: New (relocated from /make/custom).
* make/custom/simsh2e.cfg: New (relocated from /make/custom).
* make/custom/simsh4.cfg: New (relocated from /make/custom).
* make/custom/gensh4.cfg: New (relocated from /make/custom).
* make/custom/gensh2.cfg: New (relocated from /make/custom).
* make/custom/gensh1.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Mark as a small memory BSP.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* preinstall.am: Regenerated.
* Makefile.am: Remove scitab.c (Not applicable).
* acinclude.m4: simsh4 folded into shsim.
* Makefile.am, preinstall.am, include/bsp.h, include/tm27.h,
trap34/console-io.c: Now builds cleanly for runs for SH1, SH2, and
SH4.
* include/syscall.h: New file.
* include/gdbsci.h: Removed.
* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am,
simsh4/README, simsh4/bsp_specs, simsh4/configure.ac,
simsh4/preinstall.am, simsh4/clock/ckinit.c,
simsh4/console/console.c, simsh4/include/.cvsignore,
simsh4/include/bsp.h, simsh4/include/coverhd.h,
simsh4/include/ramdisk.h, simsh4/include/syscall.h,
simsh4/include/tm27.h, simsh4/start/start.S,
simsh4/startup/hw_init.c, simsh4/startup/linkcmds,
simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff,
simsh4/timer/timer.c, simsh4/tools/.cvsignore,
simsh4/tools/ChangeLog, simsh4/tools/Makefile.am,
simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* startup/linkcmds: GDB Simulator has 16MB RAM.
* Makefile.am: Now runs using fake clock ticker.
* clock/clockdrv.c: Removed.
* clock/clockdrv.c: Fix comment.
* Makefile.am, configure.ac, clock/clockdrv.c, include/bsp.h,
start/start.S, startup/linkcmds: Now runs ticker and hello on
sh-rtems4.10-gdb. The SH simulator in gdb has no hardware IO or
interrupt simulation so we use the trap interface to print.
* gdbsci/gdbsci.c: Removed.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac: Use standardized bsp_cleanup() which can
optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* startup/bspclean.c: Removed.
* shared/bspgetworkarea.c: Removed.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.sim: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, startup/linkcmds, startup/linkcmds.ram,
startup/linkcmds.rom: Use top level shared bsp_get_work_area()
implementation.
* startup/bspstart.c: Removed.
* clock/ckinit.c: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h. All
SuperH BSPs now share a common bsp_start() implementation.
