* clock/Makefile.am: Misc cleanups and fixes.
* timer/Makefile.am: Misc cleanups and fixes.
* Makefile.am: Misc cleanups and fixes.
* configure.ac: Require automake 1.7.2.
* Makefile.am: Cosmetics.
* gdbsci/Makefile.am: Cosmetics.
* scitab/Makefile.am: Cosmetics.
* trap34/Makefile.am: Cosmetics.
* hw_init/Makefile.am: Cosmetics.
* gdbsci/Makefile.am: Remove all-local: $(ARCH).
* scitab/Makefile.am: Remove all-local: $(ARCH).
* trap34/Makefile.am: Remove all-local: $(ARCH).
* hw_init/Makefile.am: Remove all-local: $(ARCH).
* ChangeLog: Add (missed in previous commits).
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
include/ramdisk.h, start/start.S, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le.coff,
timer/timer.c, tools/runtest.in: URL for license changed.
* include/bsp.h, start/start.S, startup/bspstart.c,
trap34/console-io.c: URL for license changed.
* console.c, setvec.c: URL for license changed.
* console/console.c, hw_init/hw_init.c, include/bsp.h,
include/coverhd.h, include/sdram.h, start/start.S,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram: URL for license changed.
* console/config.c, include/bsp.h, include/coverhd.h, start/start.S,
start/start.ram, start/start.rom, startup/bspclean.c,
startup/bspstart.c, startup/hw_init.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: URL for license changed.
* include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds: URL for license changed.
* Makefile.am: Add tools to SUBDIRS.
* configure.ac: Add RTEMS_CONFIG_BUILD_SUBDIRS(tools).
* ChangeLog: New.
* .cvsignore: New.
* configure.ac: New.
* runtest: Removed.
* runtest.in: New (Copied from runtest).
Use @RTEMS_BSP@ instead of simsh4.
* console/console.c: Correct copyright statements.
tools/Makefile.am: Reflect having moved automake.
gdbsci/Makefile.am: Reflect having moved automake.
scitab/Makefile.am: Reflect having moved automake.
trap34/Makefile.am: Reflect having moved automake.
hw_init/Makefile.am: Reflect having moved automake.
* tools/runtest: Add fileio to list of interactive tests.
* runtest: Add fileio to list of interactive tests.
* console/console.c, startup/linkcmds: Removed warnings.
* startup/linkcmds: Removed warnings.
PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* startup/linkcmds: Fix to work around truncated section names.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
