* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 10 | -10/+0 |
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 4 | -2/+10 |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 4 | -3/+8 |
| | | | | | * startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add .gnu.linkonce.b.* section. | ||||
| | | | | | * startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add .gnu.linkonce.b.* section. | ||||
| | | | | | * startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add .gnu.linkonce.b.* section. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -6/+14 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -12/+14 |
| | | | | | * startup/linkcmds, startup/linkcmds-le, startup/linkcmds-le.coff: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -12/+11 |
| | | | | | * startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Add sections required by newer gcc versions. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 4 | -9/+14 |
| | | | | | * startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add sections required by newer gcc versions. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 5 | -5/+5 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 5 | -0/+20 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 5 | -10/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 2 | -2/+2 |
* | Remove unnecessary CLEANFILES. | Ralf Corsepius | 2006-01-12 | 5 | -12/+3 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 10 | -271/+27 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 5 | -0/+310 |
* | 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-10-16 | 1 | -17/+43 |
| | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am. | ||||
* | Remove shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -2/+1 |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-10-16 | 1 | -1/+5 |
* | Remove. | Ralf Corsepius | 2005-10-16 | 3 | -46/+0 |
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 10 | -10/+30 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-05-20 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-20 | 1 | -0/+5 |
| | | | | | * Makefile.am: Add SHGEN. * startup/linkcmds: Add missing sections. | ||||
* | Add missing sections. | Ralf Corsepius | 2005-05-20 | 1 | -2/+5 |
* | Add SHGEN. | Ralf Corsepius | 2005-05-20 | 1 | -0/+2 |
* | 2005-05-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-11 | 4 | -2/+10 |
| | | | | * startup/linkcmds: Add .rodata.* sections. | ||||
* | 2005-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-03 | 4 | -6/+11 |
| | | | | | * startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix overflow of _CPU_Interrupt_stack_high calculation. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 10 | -19/+39 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | Fix typo. | Ralf Corsepius | 2005-01-05 | 3 | -3/+9 |
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 10 | -319/+115 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 7 | -7/+7 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 14 | -7/+35 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 15 | -26/+72 |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | ||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-22 | 15 | -105/+230 |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 10 | -51/+25 |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 10 | -5/+25 |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 22 | -37/+0 |
* | 2004-04-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-20 | 2 | -2/+4 |
| | | | | * Makefile.am: Remove C_FILES (Unused). | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-16 | 36 | -209/+209 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 5 | -7/+0 |
* | * start/start.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 10 | -5/+25 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 6 | -6/+18 |
| | | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * startup/hw_init.c: Include <rtems/iosupp.h> instead of <iosupp.h>. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 3 | -3/+9 |
| | | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * gdbsci/gdbsci.c: Include <rtems/iosupp.h> instead of <iosupp.h>. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -1/+5 |
| | | | | * console.c: Include <rtems/iosupp.h> instead of <iosupp.h>. | ||||
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 4 | -4/+14 |
| | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 6 | -24/+34 |
| | | | | | * include/bsp.h, startup/bspstart.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 4 | -15/+20 |
| | | | | | * gdbsci/gdbsci.c, include/bsp.h, startup/bspstart.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 5 | -14/+19 |
| | | | | | * clock/ckinit.c, include/bsp.h, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 4 | -10/+13 |
| | | | | | * include/bsp.h, startup/bspstart.c, startup/hw_init.c: Convert to using c99 fixed size types. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 5 | -10/+0 |
* | Unused. | Ralf Corsepius | 2004-03-08 | 8 | -16/+0 |
