* | bsps: Move extern "C" to not cover includes | Sebastian Huber | 2014-10-23 | 4 | -16/+16 |
| | | | | Some includes may use C++ and this conflicts if surrounded extern "C". | ||||
* | libbsp/sh/shared/console.c: Eliminate use of obsolete method | Joel Sherrill | 2014-10-20 | 1 | -46/+21 |
* | sh/shsim: Further clean up and fixes to previous commit | Joel Sherrill | 2014-10-19 | 4 | -2/+5 |
* | SH libcpu and libbsp: Fix warnings | Joel Sherrill | 2014-10-16 | 10 | -271/+299 |
* | Add console-polled.h and update all BSPs that should use it. | Joel Sherrill | 2014-10-10 | 3 | -3/+9 |
| | | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static. | ||||
* | sh/shared/startup/bspstart.c: Add include of <bsp/bootcard.h> to fix warning ↵ | Joel Sherrill | 2014-10-09 | 1 | -5/+5 |
| | | | | and clean up | ||||
* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 2 | -9/+9 |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | ||||
* | Regenerate all preinstall.am files. | Joel Sherrill | 2014-08-28 | 4 | -19/+19 |
| | | | | | Apparently, at some point automake output changed and these were not updated. | ||||
* | gensh4: Improve ROM vs RAM startup configuration | Joel Sherrill | 2014-08-25 | 2 | -9/+16 |
* | gensh4/bsp_specs: Account for big/little endian | Joel Sherrill | 2014-08-25 | 1 | -1/+1 |
* | simsh4-testsuite.tcfg: new file | Joel Sherrill | 2014-08-25 | 1 | -1/+5 |
* | simsh2e-testsuite.tcfg: new file | Joel Sherrill | 2014-08-25 | 1 | -1/+5 |
* | shsim/bsp_specs: Account for big/little endian | Joel Sherrill | 2014-08-25 | 1 | -1/+1 |
* | bsps: Do not build tests that require a tick interrupt. | Chris Johns | 2014-05-28 | 4 | -0/+14 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The following BSPs do not have tick support so the tests fail: arm1136jfs arm1136js arm7tdmi arm920 armcortexa9 (does not run any more) avrtest h8sim h8sxsim m32csim m32rsim moxiesim simsh1 simsh2 simsh4 v850e1sim v850e2sim v850e2v3sim v850esim v850essim v850sim This list was provided by Joel in the following post: http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html | ||||
* | multiple BSPs: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 3 | -6/+0 |
* | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 2014-05-05 | 4 | -0/+32 |
| | | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. | ||||
* | shsim: Correct linking for C++ | Joel Sherrill | 2014-04-22 | 2 | -16/+13 |
* | gensh4: Correct linking for C++ | Joel Sherrill | 2014-04-22 | 2 | -42/+8 |
* | gensh2: Correct linking for C++ | Joel Sherrill | 2014-04-22 | 2 | -16/+8 |
* | gensh1: Correct linking for C++ | Joel Sherrill | 2014-04-22 | 2 | -16/+8 |
* | libcpu/sh: Build cache stubs so apps usign cache API link | Joel Sherrill | 2014-04-22 | 3 | -3/+6 |
* | shsim: Add printk() support and move all code to console subdirectory | Joel Sherrill | 2014-04-22 | 4 | -10/+55 |
* | bsps: Fix TLS support in linker command files | Sebastian Huber | 2014-04-22 | 9 | -9/+27 |
| | | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | ||||
* | gensh1/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+2 |
* | gensh2/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+2 |
* | gensh4/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -10/+2 |
* | shsim/include/bsp.h: Remove rtems_bsp_delay() | Joel Sherrill | 2014-03-21 | 1 | -12/+2 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 30 | -30/+30 |
* | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 2014-02-04 | 9 | -16/+142 |
* | libbsp sh: Add Doxygen file header to coverhd.h | Cynthia Rempel | 2014-01-14 | 2 | -2/+14 |
* | libbsp tm27.h: Add Doxygen file header to all tm27.h | Cynthia Rempel | 2014-01-09 | 1 | -2/+6 |
* | bsps: Simplify FreeBSD linker sets | Sebastian Huber | 2013-12-16 | 1 | -15/+5 |
* | bsp: Move bspstart.c to sh/shared/startup/ | Szkocsovszki Zsolt | 2013-12-14 | 5 | -4/+4 |
* | bsps: Delete bspreset_fatal.c | Sebastian Huber | 2013-06-24 | 1 | -1/+1 |
| | | | | Use bspreset_loop.c instead. This avoids infinite recursion. | ||||
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 5 | -2744/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 1 | -2/+2 |
* | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 2012-11-15 | 4 | -0/+4 |
| | | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | ||||
* | Revert "Add bspopts.h.in." | Gedare Bloom | 2012-08-06 | 4 | -157/+0 |
| | | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files. | ||||
* | Require automake-1.12.2. | Ralf Corsépius | 2012-07-19 | 5 | -5/+5 |
* | Require autoconf-2.69. | Ralf Corsépius | 2012-07-19 | 5 | -5/+5 |
* | shsim linkcmds: Add new FreeBSD TCP/IP stack sections | Joel Sherrill | 2012-07-14 | 1 | -0/+24 |
* | Add bspopts.h.in. | Ralf Corsépius | 2012-05-24 | 4 | -0/+157 |
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 2 | -4/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 55 | -129/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 10 | -0/+30 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 10 | -30/+0 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 1 | -1/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 9 | -54/+0 |
* | 2011-10-18 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-10-18 | 2 | -7/+9 |
| | | | | | | PR 1917/bsps * console/config.c: Modifications to add dynamic tables for libchip serial drivers. | ||||
* | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-11 | 2 | -1/+6 |
| | | | | | * hw_init/hw_init.c: Use "__asm__" instead of "asm" for improved c99-compliance. |
