* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hw_init/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* console/Makefile.am: C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o).
* wrapup/Makefile.am: Add gdbsci, scitab to BSP_FILES, add
CPU_FILES.
* configure.ac: Replace RTEMS_BSPOPTS_BSP with RTEMS_BSPOPTS_SET (typo).
* configure.ac: Add RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ),
RTEMS_BSPOPTS_*(START_HW_INIT),
RTEMS_BSPOPTS_*(STANDALONE_EVB).
* wrapup/Makefile.am: Apply RTEMS_CPU_MODEL to pickup CPU_PIECES.
* startup/linkcmds: Remove explicit force of output format.
* README, console/console.c, hw_init/hw_init.c, include/bsp.h,
startup/bspstart.c, startup/linkcmds: Minor fixes post merge.
* tools: New subdirectory.
* tools/Makefile.am, tools/runtest: New files.
* startup/Makefile.am: Remove AC_CFLAGS, HZ.
* console/.cvsignore: New file.
* configure.ac: Added support for START_HW_INIT.
* console/Makefile.am: Removed VPATH.
* include/Makefile.am: Added missing ramdisk.h to include_HEADERS.
* startup/linkcmds: Do not force output format to coff-sh.
* startup/linkcmds-le: Comment out force of output format and add
comment questioning need to have special linkcmds for little endian.
* wrapup/Makefile.am: Add ramdisk to list of BSP_PIECES.
* acinclude.m4: Add gensh4 and simsh4.
* configure.ac: Remove AC_SUBST(CPU_CLOCK_RATE_HZ), add
START_HW_INIT-support macros, add console/Makefile.
* Makefile.am: Add console SUBDIR.
* hw_init/Makefile.am: Fix C_FILES, remove AM_CPPFLAGS/HZ.
* include/Makefile.am: Add bspopts.h.
* include/bsp.h: Comment out SH4_CPU_HZ_Frequency.
* startup/bspstart.c: Comment out SH4_CPU_HZ_Frequency.
* startup/linkcmds: Comment out OUTPUT_FORMAT for coff
compatibility.
* wrapup/Makefile.am: Add console to BSP_PIECES.
* console/Makefile.am: New.
* console/console.c: Moved from libcpu/sh/sh7750/sci/console.c.
* start/start.S: Fixed typo.
* include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds: Fixed typo.
* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
* console.c, setvec.c: Fixed typo.
* configure.in: Remove.
* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h* bspopts.h*
* include/bsp.h: Add bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
hw_init/.cvsignore, times, configure.ac, ChangeLog: New files.
* acinclude.m4: New file.
* startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* scitab/Makefile.am: Remove stray blank from SCITAB rule.
* include/bsp.h: Disabled redefinition of
CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added.
* console/config.c: New file. Definitions of externs referenced
from libbsp/shared/console.c.
* console/Makefile.am: Changed VPATH to point to
libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* scitab/Makefile.am: Use @CPU_CLOCK_RATE_HZ@.
* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), adapt
bspopts.h handling to other sh-BSPs.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* startup/bspstart.c: Reworked, based on the amos BSP.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
add bspopts.h.
* scitab/.cvsignore: Add.
* configure.in: Add --enable-console, CPU_CLOCK_RATE_HZ, autoheader
bspopt.h.
* include/bsp.h: Complete rewrite based on the AMOS-BSP.
* README: Update.
* bsp_specs: copy from gensh1
* Makefile.am: Add scitab, gdbsci to SUBDIRS.
* include/gdbsci.h: New file.
* include/.cvsignore: Add stamp-h? and bspopts.h*.
* console/Makefile.am: Use shared/console.c.
* console/console-io.c, console/console-support.S: Remove.
* gdbsci/, scitab/, trap34/: Add directories.
* startup/linkcmds: Remove OUTPUT_FORMAT.
* Makefile.am, README, console/console-io.c, start/start.S,
startup/linkcmds: Update to make shsim closer to functional.
* README.EVB7045F: New file.
* README: Additions and corrections.
* include/bsp.h: Switch console to sci0.
* scitab/Makefile.am, startup/bspstart.c, configure.in: Removed
rest of make-target-options and moved them to BSP configure options.
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
