These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1917/bsps
* console/config.c: Modifications to add dynamic tables for libchip
serial drivers.
* hw_init/hw_init.c:
* Makefile.am, preinstall.am, trap34/console-io.c: Install syscall.h as
bsp/syscall.h to avoid confusing autoconf.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* start/start.S: Verify boot_card is invoked properly with argc, argv.
* console/console.c: Reflect termios-API having changed.
* start/start.S: Verify boot_card() is passed a NULL.
* make/custom/simsh1.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh2.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh2e.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh4.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gensh4.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gensh2.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gensh1.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/simsh1.cfg: New (relocated from /make/custom).
* make/custom/simsh2.cfg: New (relocated from /make/custom).
* make/custom/simsh2e.cfg: New (relocated from /make/custom).
* make/custom/simsh4.cfg: New (relocated from /make/custom).
* make/custom/gensh4.cfg: New (relocated from /make/custom).
* make/custom/gensh2.cfg: New (relocated from /make/custom).
* make/custom/gensh1.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Mark as a small memory BSP.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* preinstall.am: Regenerated.
* Makefile.am: Remove scitab.c (Not applicable).
* acinclude.m4: simsh4 folded into shsim.
* Makefile.am, preinstall.am, include/bsp.h, include/tm27.h,
trap34/console-io.c: Now builds cleanly for runs for SH1, SH2, and
SH4.
* include/syscall.h: New file.
* include/gdbsci.h: Removed.
* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am,
simsh4/README, simsh4/bsp_specs, simsh4/configure.ac,
simsh4/preinstall.am, simsh4/clock/ckinit.c,
simsh4/console/console.c, simsh4/include/.cvsignore,
simsh4/include/bsp.h, simsh4/include/coverhd.h,
simsh4/include/ramdisk.h, simsh4/include/syscall.h,
simsh4/include/tm27.h, simsh4/start/start.S,
simsh4/startup/hw_init.c, simsh4/startup/linkcmds,
simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff,
simsh4/timer/timer.c, simsh4/tools/.cvsignore,
simsh4/tools/ChangeLog, simsh4/tools/Makefile.am,
simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* startup/linkcmds: GDB Simulator has 16MB RAM.
* Makefile.am: Now runs using fake clock ticker.
* clock/clockdrv.c: Removed.
* clock/clockdrv.c: Fix comment.
* Makefile.am, configure.ac, clock/clockdrv.c, include/bsp.h,
start/start.S, startup/linkcmds: Now runs ticker and hello on
sh-rtems4.10-gdb. The SH simulator in gdb has no hardware IO or
interrupt simulation so we use the trap interface to print.
* gdbsci/gdbsci.c: Removed.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
