* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), adapt
bspopts.h handling to other sh-BSPs.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* startup/bspstart.c: Reworked, based on the amos BSP.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* include/bsp.h: Add bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
add bspopts.h.
* scitab/.cvsignore: Add.
* configure.in: Add --enable-console, CPU_CLOCK_RATE_HZ, autoheader
bspopt.h.
* include/bsp.h: Complete rewrite based on the AMOS-BSP.
* README: Update.
* bsp_specs: copy from gensh1
* Makefile.am: Add scitab, gdbsci to SUBDIRS.
* include/gdbsci.h: New file.
* include/.cvsignore: Add stamp-h? and bspopts.h*.
* console/Makefile.am: Use shared/console.c.
* console/console-io.c, console/console-support.S: Remove.
* gdbsci/, scitab/, trap34/: Add directories.
* startup/linkcmds: Remove OUTPUT_FORMAT.
* Makefile.am, README, console/console-io.c, start/start.S,
startup/linkcmds: Update to make shsim closer to functional.
* README.EVB7045F: New file.
* README: Additions and corrections.
* include/bsp.h: Switch console to sci0.
* scitab/Makefile.am, startup/bspstart.c, configure.in: Removed
rest of make-target-options and moved them to BSP configure options.
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
* console/console-io.c: Added console_initialize_hardware().
* The shsim is for the SH simulator in gdb. It should be able
to be used with multiple SH CPU models.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, console/console-support.S,
start/.cvsignore, start/Makefile.am, start/regs.S,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore,
wrapup/Makefile.am: New files.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* scitab/Makefile.am: PROJECT_TOPdir.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
are his notes:
installation prefix).
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
information on hardware settings.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
John Mills <jmills@tga.com>.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
Somehow a nasty bug has made it in sh/start.S ("|", instead of "!", to
begin an asm comment).
I have no idea how this could remain undiscovered for so long (It is in
rtems-4.0.0, too!), however upgrading to binutils from sourceware's CVS
sh-rtems-as chokes on this bug. => I guess, either binutils changed its
conventions or an obvious bug in as has been fixed.
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
Ian Lance Taylor <ian@airs.com>.
CLEAN_ADDITIONS.
