2008-09-30 | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -26/+0 | |
* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am, simsh4/README, simsh4/bsp_specs, simsh4/configure.ac, simsh4/preinstall.am, simsh4/clock/ckinit.c, simsh4/console/console.c, simsh4/include/.cvsignore, simsh4/include/bsp.h, simsh4/include/coverhd.h, simsh4/include/ramdisk.h, simsh4/include/syscall.h, simsh4/include/tm27.h, simsh4/start/start.S, simsh4/startup/hw_init.c, simsh4/startup/linkcmds, simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff, simsh4/timer/timer.c, simsh4/tools/.cvsignore, simsh4/tools/ChangeLog, simsh4/tools/Makefile.am, simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed. | |||||
2007-01-26 | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* Makefile.am: Use MKDIR_P instead of mkdir_p. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+3 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+1 | |
* Makefile.am: Reworked. | |||||
2003-12-11 | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -7/+9 | |
* Makefile.am: Misc cleanups and fixes. * configure.ac: Require automake 1.7.2. | |||||
2003-08-21 | 2003-08-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -7/+9 | |
* ChangeLog: New. * .cvsignore: New. * configure.ac: New. * runtest: Removed. * runtest.in: New (Copied from runtest). * Makefile.am: Reflect changes above. Use @RTEMS_BSP@ instead of simsh4. | |||||
2003-08-16 | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. tools/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * tools/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2001-10-26 | 2001-10-26 Alexandra Kossovsky <sasha@oktet.ru> | Joel Sherrill | 1 | -0/+21 | |
* tools: New subdirectory. * tools/Makefile.am, tools/runtest: New files. |
