* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* startup/linkcmds: Include all .rodata* sections.
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds-le.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Added support for START_HW_INIT.
* console/Makefile.am: Removed VPATH.
* include/Makefile.am: Added missing ramdisk.h to include_HEADERS.
* startup/linkcmds: Do not force output format to coff-sh.
* startup/linkcmds-le: Comment out force of output format and add
comment questioning need to have special linkcmds for little endian.
* wrapup/Makefile.am: Add ramdisk to list of BSP_PIECES.
* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h* bspopts.h*
* include/bsp.h: Add bspopts.h.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
