include/ramdisk.h, start/start.S, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le.coff,
timer/timer.c, tools/runtest.in: URL for license changed.
tools/Makefile.am: Reflect having moved automake.
* start/Makefile.am: Eliminate PGMS.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
