* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* startup/hw_init.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c, timer/timer.c:
Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Remove bogus EXTRA_DIST.
* timer/Makefile.am: Remove bogus EXTRA_DIST.
* startup/Makefile.am: Ditto.
* Makefile.am: Regenerate.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* clock/Makefile.am: Misc cleanups and fixes.
* timer/Makefile.am: Misc cleanups and fixes.
include/ramdisk.h, start/start.S, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le.coff,
timer/timer.c, tools/runtest.in: URL for license changed.
* Makefile.am: Add tools to SUBDIRS.
* configure.ac: Add RTEMS_CONFIG_BUILD_SUBDIRS(tools).
tools/Makefile.am: Reflect having moved automake.
* tools/runtest: Add fileio to list of interactive tests.
* console/console.c, startup/linkcmds: Removed warnings.
* startup/Makefile.am, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff: Fix to work around truncated section names.
* wrapup/Makefile.am: Fix typo in CPU_PIECES handling.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds-le, startup/linkcmds-le.coff: Add FreeBSD sysctl()
sections.
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
