* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), adapt
bspopts.h handling to other sh-BSPs.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* startup/bspstart.c: Reworked, based on the amos BSP.
* scitab/.cvsignore: Add.
* configure.in: Add --enable-console, CPU_CLOCK_RATE_HZ, autoheader
bspopt.h.
* include/bsp.h: Complete rewrite based on the AMOS-BSP.
* README: Update.
* bsp_specs: copy from gensh1
* Makefile.am: Add scitab, gdbsci to SUBDIRS.
* include/gdbsci.h: New file.
* include/.cvsignore: Add stamp-h? and bspopts.h*.
* console/Makefile.am: Use shared/console.c.
* console/console-io.c, console/console-support.S: Remove.
* gdbsci/, scitab/, trap34/: Add directories.
* Makefile.am, README, console/console-io.c, start/start.S,
startup/linkcmds: Update to make shsim closer to functional.
* console/console-io.c: Added console_initialize_hardware().
* The shsim is for the SH simulator in gdb. It should be able
to be used with multiple SH CPU models.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, console/console-support.S,
start/.cvsignore, start/Makefile.am, start/regs.S,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore,
wrapup/Makefile.am: New files.
