* gdbsci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* trap34/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gdbsci/Makefile.am: Use .$(OBJEXT) instead of .o.
* scitab/Makefile.am: Use .$(OBJEXT) instead of .o.
* trap34/Makefile.am: Use .$(OBJEXT) instead of .o.
* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* start/start.S: Fixed typo.
* Makefile.am, README, console/console-io.c, start/start.S,
startup/linkcmds: Update to make shsim closer to functional.
* The shsim is for the SH simulator in gdb. It should be able
to be used with multiple SH CPU models.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, console/console-support.S,
start/.cvsignore, start/Makefile.am, start/regs.S,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore,
wrapup/Makefile.am: New files.
