* gdbsci/gdbsci.c: Include <rtems/iosupp.h> instead of <iosupp.h>.
* gdbsci/gdbsci.c, include/bsp.h, startup/bspstart.c: Convert to
using c99 fixed size types.
* Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am,
scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am,
trap34/Makefile.am: Remove.
* clock/Makefile.am: Remove bogus EXTRA_DIST.
* gdbsci/Makefile.am: Remove bogus EXTRA_DIST.
* wrapup/Makefile.am: Reflect changes to libcpu.
* gdbsci/Makefile.am: Cosmetics.
* scitab/Makefile.am: Cosmetics.
* trap34/Makefile.am: Cosmetics.
* gdbsci/Makefile.am: Remove all-local: $(ARCH).
* scitab/Makefile.am: Remove all-local: $(ARCH).
* trap34/Makefile.am: Remove all-local: $(ARCH).
gdbsci/Makefile.am: Reflect having moved automake.
scitab/Makefile.am: Reflect having moved automake.
trap34/Makefile.am: Reflect having moved automake.
* gdbsci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* trap34/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gdbsci/gdbsci.c: Removed warnings.
* gdbsci/Makefile.am: Use .$(OBJEXT) instead of .o.
* scitab/Makefile.am: Use .$(OBJEXT) instead of .o.
* trap34/Makefile.am: Use .$(OBJEXT) instead of .o.
* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gdbsci/, scitab/, trap34/: Add directories.
