2001-12-20 | 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+1 | |
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ). * console/Makefile.am: C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o). * wrapup/Makefile.am: Add gdbsci, scitab to BSP_FILES, add CPU_FILES. | |||||
2001-01-29 | 2001-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -109/+6 | |
* Makefile.am: Add scitab, gdbsci to SUBDIRS. * include/gdbsci.h: New file. * include/.cvsignore: Add stamp-h? and bspopts.h*. * console/Makefile.am: Use shared/console.c. * console/console-io.c, console/console-support.S: Remove. | |||||
2001-01-24 | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -1/+6 | |
* Makefile.am, README, console/console-io.c, start/start.S, startup/linkcmds: Update to make shsim closer to functional. | |||||
2001-01-03 | 2001-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+11 | |
* console/console-io.c: Added console_initialize_hardware(). | |||||
2000-11-27 | 2000-11-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 4 | -0/+123 | |
* The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, console/console-support.S, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
