* | 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-05-11 | 1 | -4/+5 |
| | | | | | | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), adapt bspopts.h handling to other sh-BSPs. * include/.cvsignore: Add stamp-h*, bspopts.h*. * include/Makefile.am: Use include_HEADERS instead of H_FILES. * startup/bspstart.c: Reworked, based on the amos BSP. | ||||
* | 2001-05-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-05-09 | 1 | -0/+54 |
| | | | | | | | | | * scitab/.cvsignore: Add. * configure.in: Add --enable-console, CPU_CLOCK_RATE_HZ, autoheader bspopt.h. * include/bsp.h: Complete rewrite based on the AMOS-BSP. * README: Update. * bsp_specs: copy from gensh1 | ||||
* | 2000-11-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-27 | 1 | -0/+32 |
* The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, console/console-support.S, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files. |
