* Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am,
scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am,
trap34/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
Reflect changes to bsp.am.
* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* console/Makefile.am: C_O_FILES = $(C_FILES:%.c=$(ARCH)/%.o).
* wrapup/Makefile.am: Add gdbsci, scitab to BSP_FILES, add
CPU_FILES.
* configure.in: Remove.
