2001-05-09 | 2001-05-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -8/+7 | |
* scitab/.cvsignore: Add. * configure.in: Add --enable-console, CPU_CLOCK_RATE_HZ, autoheader bspopt.h. * include/bsp.h: Complete rewrite based on the AMOS-BSP. * README: Update. * bsp_specs: copy from gensh1 | |||||
2000-11-27 | 2000-11-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+0 | |
* The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, console/console-support.S, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files. | |||||
2000-07-06 | Added baseline for h8 simulator BSP to support the simulator in gdb 5.0 | Joel Sherrill | 1 | -0/+0 | |
2000-06-12 | Added i960sim BSP which (ignoring the 3 instructions not supported | Joel Sherrill | 1 | -1/+1 | |
by gdb 5.0's i960 simulator) is enough to run hello world. | |||||
1998-03-30 | Update from "erik.ivanenko" <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1 | -1/+1 | |
Also removed bsp_postdriver_hook() from every bsp possible and moved to shared version. | |||||
1998-02-11 | Incorporated Ralf Corsepius' idea for new -q flags to properly support | Joel Sherrill | 1 | -2/+7 | |
"gmake debug". | |||||
1997-12-20 | Moved -qnolinkcmds option so arguments passed on the command line are | Joel Sherrill | 1 | -2/+2 | |
interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work! | |||||
1997-12-19 | Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds | Joel Sherrill | 1 | -1/+1 | |
switch which lets the user specify a different linker script. | |||||
1997-10-08 | Modified to search RTEMS library before Newlib C library. | Joel Sherrill | 1 | -1/+1 | |
1997-08-28 | Switched to new style which does not require hackspecs.awk. | Joel Sherrill | 1 | -29/+13 | |
1997-01-28 | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1 | -0/+34 | |
