* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am: Now runs using fake clock ticker.
* clock/clockdrv.c: Removed.
* Makefile.am, configure.ac, clock/clockdrv.c, include/bsp.h,
start/start.S, startup/linkcmds: Now runs ticker and hello on
sh-rtems4.10-gdb. The SH simulator in gdb has no hardware IO or
interrupt simulation so we use the trap interface to print.
* gdbsci/gdbsci.c: Removed.
* Makefile.am, startup/linkcmds, startup/linkcmds.sim: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, configure.ac, include/bsp.h, startup/linkcmds: Use
shared bsp_get_work_area() in its own file and rely on BSP Framework
to perform more initialization. After factoring this out, it turned
out that all SuperH BSPs has the same bsp_start() implementation so
this was made shared.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* Makefile.am, preinstall.am, startup/linkcmds: Save the old linker
script as linkcmds.sim and use one with enough memory to link all
tests so we can at least build things.
* startup/linkcmds.sim: New file.
* Makefile.am: Add dummy printk support so all tests link.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* Makefile.am: Add preinstall.am.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../sh/shared instead of
../shared. Reformat.
* Makefile.am: Cosmetics.
* Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am,
scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am,
trap34/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* gdbsci/Makefile.am: Cosmetics.
* scitab/Makefile.am: Cosmetics.
* trap34/Makefile.am: Cosmetics.
gdbsci/Makefile.am: Reflect having moved automake.
scitab/Makefile.am: Reflect having moved automake.
trap34/Makefile.am: Reflect having moved automake.
* gdbsci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* trap34/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add scitab, gdbsci to SUBDIRS.
* include/gdbsci.h: New file.
* include/.cvsignore: Add stamp-h? and bspopts.h*.
* console/Makefile.am: Use shared/console.c.
* console/console-io.c, console/console-support.S: Remove.
* Makefile.am, README, console/console-io.c, start/start.S,
startup/linkcmds: Update to make shsim closer to functional.
* The shsim is for the SH simulator in gdb. It should be able
to be used with multiple SH CPU models.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, console/console-support.S,
start/.cvsignore, start/Makefile.am, start/regs.S,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore,
wrapup/Makefile.am: New files.
* Makefile.am, clock/Makefile.am, clock/.cvsignore, wrapup/Makefile.am:
Added include of stub clock driver so ticker would link.
from cvs by adding .cvsignore files.
by gdb 5.0's i960 simulator) is enough to run hello world.
that converts the hppa1.1 directory to automake.
NOTE:
* Due to not having a toolchain (gcc refuses to build) this patch is
untested.
* I omited/deactivated the pxfl subdirectory, because I don't
understand how it supposed to work.
Joel's note: It was right to ignore the pxfl directory. It should be
removed one the BSPs are moved outside the tree. This was an old hack.
that converts the mips64orion directory to automake.
Ralf's Note: This patch demonstrates another kind of supporting the new
style of configuration, which avoids having to port all Makefile.ins to
automake, but to keep using most old style Makefile.ins.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
