PR 338/filesystem
* console.c: Side-effect of fixing reentrancy problem with
rtems_io_lookup_name() (API change).
* console.c, setvec.c: Fixed typo.
converted to automake.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
Please find enclosed a patch which enables me to build the bare-bsp for
sh-rtems.
1. Add preinstall to libbsp/bare/include/Makefile.in
2. Removed FORCEIT, add preinstall to
libbsp/sh/gensh1/include/Makefile.in
3. Disabled support of set_vector from sh code (shared/setvec.c is still
present but isn't used anymore), set_vector replaced with standard rtems
functions.
Problems still present:
1. Support of spin-delays in bare bsp
2. Proper support of cpu frequency
To configure I used:
<srcdir>/configure \
--target=sh-rtems \
--prefix=<instdir>/sh-bare \
--enable-bare-cpu-cflags='-Wall -m1 -DMHZ=20
-DCPU_CONSOLE_DEVNAME="\"/dev/null\""'
--enable-rtemsbsp=bare \
--disable-networking \
--disable-cxx \
--disable-posix \
--disable-tests
IMO, if there are no objections to this patch, a similar approach should
be applied to all CPUs/BSPs (esp. hppa1.1, mips64orion, ppc403, because
they apply set_vector inside of libcpu).
