hw_init/Makefile.am: Reflect having moved automake.
* startup/linkcmds: Removed warnings.
* startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: Fix
to work around truncated section names.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* startup/linkcmds.rom, startup/linkcmds.rom2ram: Add FreeBSD sysctl()
sections.
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
* hw_init/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* hw_init/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: Added __EH_FRAME_BEGIN__ and __EH_FRAME_END__
to remove problems linking empty main(){} with BSP.
* start/Makefile.am: Eliminate PGMS.
* startup/Makefile.am: Add bsplib_DATA = linkcmds linkcmds.rom
linkcmds.rom2ram.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* hw_init/Makefile.am: Remove AUTOMAKE_OPTIONS.
* startup/linkcmds: Remove explicit force of output format.
* README, console/console.c, hw_init/hw_init.c, include/bsp.h,
startup/bspstart.c, startup/linkcmds: Minor fixes post merge.
* console/.cvsignore: New file.
* configure.ac: Remove AC_SUBST(CPU_CLOCK_RATE_HZ), add
START_HW_INIT-support macros, add console/Makefile.
* Makefile.am: Add console SUBDIR.
* hw_init/Makefile.am: Fix C_FILES, remove AM_CPPFLAGS/HZ.
* include/Makefile.am: Add bspopts.h.
* include/bsp.h: Comment out SH4_CPU_HZ_Frequency.
* startup/bspstart.c: Comment out SH4_CPU_HZ_Frequency.
* startup/linkcmds: Comment out OUTPUT_FORMAT for coff
compatibility.
* wrapup/Makefile.am: Add console to BSP_PIECES.
* console/Makefile.am: New.
* console/console.c: Moved from libcpu/sh/sh7750/sci/console.c.
* configure.in: Remove.
* configure.ac: Add bspopts.h; Add CPU_CLOCK_RATE_HZ.
* startup/bspstart.c: Replace HZ with CPU_CLOCK_RATE_HZ.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/bsp.h: Add bspopts.h.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
hw_init/.cvsignore, times, configure.ac, ChangeLog: New files.
