* console/console.c: Correct copyright statements.
hw_init/Makefile.am: Reflect having moved automake.
* hw_init/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* hw_init/Makefile.am: Use .$(OBJEXT) instead of .o.
* hw_init/Makefile.am: Remove AUTOMAKE_OPTIONS.
* README, console/console.c, hw_init/hw_init.c, include/bsp.h,
startup/bspstart.c, startup/linkcmds: Minor fixes post merge.
* console/.cvsignore: New file.
* configure.ac: Remove AC_SUBST(CPU_CLOCK_RATE_HZ), add
START_HW_INIT-support macros, add console/Makefile.
* Makefile.am: Add console SUBDIR.
* hw_init/Makefile.am: Fix C_FILES, remove AM_CPPFLAGS/HZ.
* include/Makefile.am: Add bspopts.h.
* include/bsp.h: Comment out SH4_CPU_HZ_Frequency.
* startup/bspstart.c: Comment out SH4_CPU_HZ_Frequency.
* startup/linkcmds: Comment out OUTPUT_FORMAT for coff
compatibility.
* wrapup/Makefile.am: Add console to BSP_PIECES.
* console/Makefile.am: New.
* console/console.c: Moved from libcpu/sh/sh7750/sci/console.c.
