* startup/Makefile.am: Remove AC_CFLAGS, HZ.
* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
* configure.in: Remove.
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am,
include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore,
start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom,
startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am,
wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c,
hw_init/.cvsignore, times, configure.ac: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* scitab/Makefile.am: Remove stray blank from SCITAB rule.
* include/bsp.h: Disabled redefinition of
CONSOLE_DRIVER_TABLE_ENTRY. Some "FIXME:" comments added.
* console/config.c: New file. Definitions of externs referenced
from libbsp/shared/console.c.
* console/Makefile.am: Changed VPATH to point to
libbsp/shared. Added config.c to C_FILES and EXTRA_DIST.
* scitab/Makefile.am: Use @CPU_CLOCK_RATE_HZ@.
* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* include/bsp.h: Add bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
* startup/linkcmds: Remove OUTPUT_FORMAT.
* README.EVB7045F: New file.
* README: Additions and corrections.
* include/bsp.h: Switch console to sci0.
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
* scitab/Makefile.am: PROJECT_TOPdir.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
are his notes:
installation prefix).
that contains:
* Removes MKLIB
handling)
converted to automake.
information on hardware settings.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
John Mills <jmills@tga.com>.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
