* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
BSP_BOOTCARD_OPTIONS.
* Makefile.am, startup/linkcmds, startup/linkcmds.ram,
startup/linkcmds.rom: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, configure.ac, include/bsp.h, startup/linkcmds: Use
shared bsp_get_work_area() in its own file and rely on BSP Framework
to perform more initialization. After factoring this out, it turned
out that all SuperH BSPs has the same bsp_start() implementation so
this was made shared.
* startup/bspstart.c: Removed.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* startup/bspstart.c: Eliminate the clicks_per_microsecond field in the
SuperH CPU Table and define another mechanism for drivers to obtain
this information.
* Makefile.am: Separate debug IO from console so console driver is not
linked in all the time. This manaifested itself when the IO manager
optional manager stub dropped some symbols.
* startup/linkcmds: Handle .data.* sections
* bsp_specs: Remove qrtems_debug.
* Makefile.am: Add dummy printk support so all tests link.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
.rela.dyn sections.
.gnu.linkonce.b.* section.
sections required by newer gcc versions.
* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* startup/linkcmds: Add .rodata.* sections.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix
overflow of _CPU_Interrupt_stack_high calculation.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
