* console/config.c, include/bsp.h, include/coverhd.h, start/start.S,
start/start.ram, start/start.rom, startup/bspclean.c,
startup/bspstart.c, startup/hw_init.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: URL for license changed.
scitab/Makefile.am: Reflect having moved automake.
* startup/linkcmds: Removed warnings.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Fix to
work around truncated section names.
* startup/linkcmds, startup/linkcmds.ram, startup/linkcmds.rom: Add
FreeBSD sysctl() sections.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* startup/linkcmds: Include all .rodata* sections.
* start/start.S, startup/hw_init.c: Removed warnings.
* startup/bspstart.c: As part of fixing PR281 on gensh4, a review
of all calls to bsp_libc_init() resulted in some cleanup here.
* scitab/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: Added __EH_FRAME_BEGIN__ and __EH_FRAME_END__
to remove problems linking empty main(){} with BSP.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* startup/Makefile.am: Remove AC_CFLAGS, HZ.
* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
* startup/Makefile.am: Use 'PREINSTALL_FILES ='.
* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* include/bsp.h: Add bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
* startup/linkcmds: Remove OUTPUT_FORMAT.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
converted to automake.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
John Mills <jmills@tga.com>.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
