* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
