* include/bsp.h, start/start.S, start/start.ram, start/start.rom,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/linkcmds.ram, startup/linkcmds.rom: Fixed typo.
* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]), add
bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* include/bsp.h: Add bspopts.h.
* startup/bspstart.c: Replace HZ w/ CPU_CLOCK_RATE_HZ.
John Mills <jmills@tga.com>.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
