* Makefile.am: Merge-in console/Makefile.am, scitab/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* console/Makefile.am, scitab/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Remove.
* scitab/Makefile.am: Remove all-local: $(ARCH).
scitab/Makefile.am: Reflect having moved automake.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scitab/Makefile.am: Use .$(OBJEXT) instead of .o.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* scitab/Makefile.am: Remove stray blank from SCITAB rule.
* scitab/Makefile.am: Use @CPU_CLOCK_RATE_HZ@.
* scitab/Makefile.am, startup/Makefile.am: Use CPU_CLOCK_RATE_HZ as
it is called in configure.in instead of HZ.
* scitab/Makefile.am: PROJECT_TOPdir.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
converted to automake.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
