* configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]),
add bspopts.h.
* include/.cvsignore: Add stamp-h*, bspopts.h*.
* include/Makefile.am: Use include_HEADERS instead of H_FILES.
* include/bsp.h: Add bspopts.h.
* startup/linkcmds: Remove OUTPUT_FORMAT.
* scitab/Makefile.am, startup/bspstart.c, configure.in: Removed
rest of make-target-options and moved them to BSP configure options.
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
* startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and
* scitab/Makefile.am: PROJECT_TOPdir.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
are his notes:
installation prefix).
that contains:
* Removes MKLIB
handling)
converted to automake.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
1. SH-Port:
* Many files renamed.
applying VPATH.
2. SH1-Port
3. SH2-Port
* Merged
you don't mind).
Somehow a nasty bug has made it in sh/start.S ("|", instead of "!", to
begin an asm comment).
I have no idea how this could remain undiscovered for so long (It is in
rtems-4.0.0, too!), however upgrading to binutils from sourceware's CVS
sh-rtems-as chokes on this bug. => I guess, either binutils changed its
conventions or an obvious bug in as has been fixed.
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
Ian Lance Taylor <ian@airs.com>.
CLEAN_ADDITIONS.
future.
cd <rtems-source-tree>
all bsp_specs.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
Here is a cosmetic patch which corrects a few spelling problems in parts
written by me.
Apparently, I must have written these under the influence of ether (:-)
Please find enclosed a patch which enables me to build the bare-bsp for
sh-rtems.
1. Add preinstall to libbsp/bare/include/Makefile.in
2. Removed FORCEIT, add preinstall to
libbsp/sh/gensh1/include/Makefile.in
3. Disabled support of set_vector from sh code (shared/setvec.c is still
present but isn't used anymore), set_vector replaced with standard rtems
functions.
Problems still present:
1. Support of spin-delays in bare bsp
2. Proper support of cpu frequency
To configure I used:
<srcdir>/configure \
--target=sh-rtems \
--prefix=<instdir>/sh-bare \
--enable-bare-cpu-cflags='-Wall -m1 -DMHZ=20
-DCPU_CONSOLE_DEVNAME="\"/dev/null\""'
--enable-rtemsbsp=bare \
--disable-networking \
--disable-cxx \
--disable-posix \
--disable-tests
IMO, if there are no objections to this patch, a similar approach should
be applied to all CPUs/BSPs (esp. hppa1.1, mips64orion, ppc403, because
they apply set_vector inside of libcpu).
* c/src/lib/libbsp/sh/gensh1/scitab - NEW DIRECTORY
Location for building the table generated by shgen
