* Makefile.am: Merge-in console/Makefile.am, scitab/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am.
Use automake-compilation rules.
* console/Makefile.am, scitab/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* scitab/Makefile.am: Cosmetics.
* scitab/Makefile.am: Remove all-local: $(ARCH).
scitab/Makefile.am: Reflect having moved automake.
* wrapup/Makefile.am: Reflect changes to libcpu/sh/*.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* wrapup/Makefile.am: Apply RTEMS_CPU_MODEL to pickup CPU_PIECES.
* include/bsp.h: Changed <sh/null.h> to <rtems/devnull.h> to reflect
the movement of this component to libmisc.
* wrapup/Makefile.am: /dev/null driver is no longer in libcpu/sh.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
are his notes:
installation prefix).
converted to automake.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
that converts the libbsp/i386 subdirectory to full automake.
