Update #3285.
* start/start.S: Verify boot_card is invoked properly with argc, argv.
* start/start.S: Update for boot_card command line change.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* scitab/Makefile.am: Remove all-local: $(ARCH).
* include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/linkcmds: URL for license changed.
scitab/Makefile.am: Reflect having moved automake.
* scitab/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* scitab/Makefile.am: Use .$(OBJEXT) instead of .o.
* scitab/Makefile.am: Remove AUTOMAKE_OPTIONS.
startup/bspstart.c, startup/linkcmds: Fixed typo.
* console/Makefile.am, scitab/Makefile.am, start/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
converted to automake.
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
Somehow a nasty bug has made it in sh/start.S ("|", instead of "!", to
begin an asm comment).
I have no idea how this could remain undiscovered for so long (It is in
rtems-4.0.0, too!), however upgrading to binutils from sourceware's CVS
sh-rtems-as chokes on this bug. => I guess, either binutils changed its
conventions or an obvious bug in as has been fixed.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
