* Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore,
irq/.cvsignore, network/.cvsignore, startup/.cvsignore,
vectors/.cvsignore. Use automake compilation rules.
* clock/.cvsignore, console/.cvsignore, irq/.cvsignore,
network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove.
* wrapup/Makefile: Reflect changes above.
network/Makefile.am, nvram/Makefile.am, pci/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
universe/Makefile.am, vectors/Makefile.am. Use automake compilation
rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
nvram/Makefile.am, pci/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, universe/Makefile.am,
vectors/Makefile.am: Remove.
PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am,
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
* Makefile.am: Merge-in dlentry/Makefile.am, flashentry/Makefile.am,
startup/Makefile.am. Use automake compilation rules.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am:
Remove.
scv64/Makefile.am, sonic/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am: Remove.
* configure.ac, wrapup/Makefile.am: Reflect changes above.
* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use
* dlentry/Makefile.am, startup/Makefile.am: Remove.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* Makefile.am: Merge-in canbus/Makefile.am, clock/Makefile.am,
console/Makefile.am, irq/Makefile.am, network/Makefile.am,
* canbus/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, vme/Makefile.am.
Rename clock.rel to pclock.rel (Conflict with libcpu).
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* console/Makefile.am: Add PREINSTALL_DIRS.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* motorola/Makefile.am: Add PREINSTALL_DIRS.
* openpic/Makefile.am: Add PREINSTALL_DIRS.
* pci/Makefile.am: Add PREINSTALL_DIRS.
* residual/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* vme/Makefile.am: Add PREINSTALL_DIRS.
* startup/Makefile.am: Ditto.
* console/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Ditto.
* motorola/Makefile.am: Ditto.
* openpic/Makefile.am: Ditto.
* pci/Makefile.am: Ditto.
* residual/Makefile.am: Ditto.
* vectors/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* bootloader/Makefile.am: Ditto.
* vme/Makefile.am: Ditto.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* tod/Makefile.am: Cosmetics.
* console/Makefile.am: Eliminate *.rel.
Use $(top_srcdir)/../../shared instead of ../../../shared.
* start/Makefile.am: Add BUILD-VARIANTS.
* vectors/Makefile.am: Fix typos.
* vme/Makefile.am: Fix typos.
* PCI_bus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* shmsupp/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* nvram/Makefile.am: Eliminate VPATH.
* pci/Makefile.am: Eliminate VPATH.
* universe/Makefile.am: Eliminate VPATH.
* irq/Makefile.am: Eliminate VPATH.
* bootloader/Makefile.am: Eliminate VPATH.
* motorola/Makefile.am: Eliminate VPATH.
* openpic/Makefile.am: Eliminate VPATH.
* residual/Makefile.am: Eliminate VPATH.
* vme/Makefile.am: Eliminate VPATH.
* ide/Makefile.am: Eliminate VPATH.
* dlentry/Makefile.am: Eliminate VPATH.
* flashentry/Makefile.am: Eliminate VPATH.
* canbus/Makefile.am: Eliminate VPATH.
* scv64/Makefile.am: Eliminate VPATH.
* sonic/Makefile.am: Eliminate VPATH.
PR 545/bsps
* startup/setvec.c: Removed.
PR 545/bsps
PR 545/bsps
* wrapup/Makefile.am: Remove GENERIC_FILES.
PR 333/bsps
* startup/linkcmds: Remove SEARCH_DIR.
